is there a way to show material color on objects on frozen layer?
when i freeze a layer if changes color to grey, is there a way to stop that happening?
thanks
10DSpace
@Anonymous
There is a check box in the Object Properties Dialogue box called  "Show Frozen in Grey".  If you want the objects in a layer to not change to grey when frozen then select all of the objects and right click>Properties and uncheck this box. Show frozen in grey2.png
that works, thanks
