Announcements
Invisible Boolean Objects with IGPU
( Using intel HD-2000 Graphics Series)
Using any operation to set a Boolean Compound Object turns all it's operands invisible. They only reappear in the ViewPort after converting it to Editable Poly.
I'm already using Legacy Hardware mode for the program tto work. Is there a workaround for this issue?
Does it work if you put an editPoly modifier on top of the Boolean?
Also, are we talking about Standard Boolean or ProBoolean? Have you tried both?
Yes, I'm using Boolean and converting the object to Editable Poly. The good new is I've just tried ProBoolean, and it works as intended though.
There's an additional issue: when clicking outside the object to deselect it , the object disappears from the viewport as soon as I move the mouse cursor again.
