Intensity mapping when using RCP file in 3ds max
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a point cloud where the scanning was done in the dark, so when viewing in Cyclone or ReCap the only way to discern geometry is using the intensity display. when using the "colors from scanner" mapping, there is only a few colored points where someone had a flashlight and the rest of the points are black.
I exported a PTS file from Cyclone and brought into ReCap and saved as an .RCP file. Now with my RCP file in 3ds max, when I select "Intensity Ramp" it apparently gives me some fudged version of the "colors from scanner". Because now the points are all orange except some changes of color where the flashlight was. It does not give nearly the color gradients seen in the Cyclone or ReCap intensity mapping.
I suspect this is a Recap issue? can someone please help?
Thank you,
Curtis
