Increase font size
Increase font size
Increase font size
Hi, I just installed 3Ds Max on my HP Pavilion and i have run into some problems. Firstly most of the text and symbols are so small you cant see them. Is there a way to increase the size of the text? Also the command panel are missing and I cant find it.
I would truly appraciate some help with these issues,
/ MIkaela
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community!
I'd like to help you with this, but I have a few questions please.  The missing command panel does sound strange.  Can you please tell me your current OS, your graphics card, and which version of 3ds Max you are using?  Thank you very much for doing so.
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on your issue?  Is it possible to provide some of the details requested in my previous post so I may better assist you?
Best Regards,
Hi! Yes the issue is solved! I changed the resolution to widescreen, and
then the symbols increased and the command panel appeard. Thank you
anyways!!
Alfred.DeFlaminis
Hello @Anonymous,
Nice work!  I will kudo your post and mark it as the solution, and thank you for updating me so I can check this for the next Pavilion command panel issue I see.  I really appreciate it.
Best Regards,
yiannisk
Anyone having such an issue in the future,
one easy solution is you can try increasing the size of text in your Windows settings.
Just type Text Size in your windows search field or the settings search.
This will increase it for the whole system.
Another simple solution is increasing the Scale in your system settings, i.e. to 125%
You can try any of these to see if any suits your needs.
