Import from autocad with specific coordinates
I have imported from Civil 3d to 3ds Max. As 3ds suggests I haven't used the original coordinates but the ones that gave me instead. Now I want to import a dwg file into the 3ds Max, but I don't how to place it in the correct coordinates ( the ones that 3ds Max gave me at first)
rendermaster
1. is your autocad dwg - part of the civil dwg..are they connected or related that you want to ask for their coordinates? If not, you can just import your autocad and relocate/move it to wherever you want in the drawing area.
2. when we import autocad to 3ds max, its 0,0,0 coordinates will be the same. so its up to you if you want to use it or move the object after importation.
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
