Import/Export Scale factor not showing
I do not know why this problem occurs, 2 years ago it happened to me but the value appeared when I did factory format my computer, now that I have a new hard disk because the old one was damaged, this problem appeared again.
It is not a problem with the files, it is the program, I tried several versions of 3DS and they are all missing, I sent the files to some friends and the scale factor always appears.
It is a problem that I want to solve, I always use the value 2.54 in centimeters to import and export camera angles for Resident Evil 1.5/2.
I searched for google and did not find any help, I looked in the forums and nothing useful.
Diffus3d
That's weird.  I suppose the first thing to try is to reset your user settings.  (Back them up first.)  If that doesn't work, then I would try to run 3dsmax as administrator and see if they show up then.
If that fails...  I'm not sure what the solution would be.  Is it possible that it's a driver issue with the graphics card?  What happens in other graphics modes?   Feels like it's trying to retrieve a value and it's not allowed to retrieve it, or it's not allowed to return it.  That makes me think it's related to settings or permissions, but I'm totally guessing.
Best Regards,
