Solved by Steve_Curley. Go to Solution.
Try to save as another file extension, like: .avi to .mov and so on.
I had the same problem.
I did save the file as fileName.mov and it didn't work but after I did save as fileName.avi, everything went good.
its codec problem I think.
hey i had a ref to how to turn multiple textures to one on a mesh by unwrapping the uv map but i installed 2k23 and lost the configuration check box settings or something can you help me out when i try bake to texture i get the image i/o error do 8 k textures even render fast enough on game engines like ue i got this shading problem i still need to make a reference notation on cage unwrapping with proxy mesh please let me know how to handle the image i/o error when it comes the uv unwrap modifier thanks in advance
