How to transform non-destructively many objects (e.g. a complete house)
BenediZ
BenediZ
Another basic question:
How can I transform Objects on a layer (lets say only for example it is a complete house) with lots of subobjects, groups, objects etc.?
In Maya I would put it in a group folder and aplly all transformations to the group and can any time modify or reset them..
In Max I did not find a way until now...
Thanks for help
10DSpace
If you double click on the layer all of the objects (including groups) in the layer will be selected and you can transform them all at once.
BenediZ
I know, but I guess this is destructive.
I could not animate this and could not reset to the original state.
I am looking for something like a XForm modifier, but to apply it to a layer, regardless what is inside that layer....
miledrizk
Try the container feature, if you don't have the toolbar already on your main UI, add it
1- Select the objects and click the Create Container From Selection
1-create container1-create container
2- You'll a Box helper create inside the viewport if you drag it around all objects will
Move like if they're a group. The Box in this state is opened that means you can select and manipulate
Individual objects manually. But before doing anything we need to save this container to disk,
So click the Save Container Button
2- Save Container2- Save Container
3- You can close the Container so that you cannot manipulate individual objects. In the Image below
You see the two buttons responsible for the Open and Close container
3-Open / Close container3-Open / Close container
4- keep your container open and do whatever you want with your object.
5- At any time you want your objects back to their state when you created the Container,
Click the Inherit Container button and point to the saved Container on your disk.
5- Inherit5- Inherit
Important Note: if at any point, you closed the container, the saved Container will be updated to reflect
The new state. So keep it open after you create the container in the state that you like to go back to.
There are many features that you can explore yourself now, it's a powerful tool.
miledrizk@gmail.com
3DS Max 2025, V-Ray 7
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
BenediZ
Sounds great, containers are a new topic for me (something Maya is missing:))
I will examine them once. Thanks
