How to see inside an object in 3ds Max
how can i see inside Object (box) 3ds max
Your post subject line has been edited by @hagen.deloss: q
leeminardi
If the box is hollow you could place a camera inside and then use a camera view.
lee.minardi
How can I see inside the box without putting the camera view
leeminardi
Change the display to wire frame or use view clipping.
lee.minardi
hagen.deloss
Hi @Anonymous
Thanks for bringing your question to the forums, it looks like you are visiting as a new member to the 3DS Max forum. I want to extend a warm welcome to the Autodesk Community!
Any ideas or questions on @leeminardi 's previous post? It would be helpful if you had time to give an update, that way other Community Members can benefit from your process 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
