Solved by CAMedeck. Go to Solution.
Chris Medeck
Chris Medeck
Thank you you saved my day
@CAMedeck wrote:
Look at the image I posted. In the center there is a circle around the radio button for Copy. That defaults to Remove, which is not really what you want to do. You want to either Copy or Instance your first box out of the Boolean. The original box no longer exists as it once did, because ProBoolean is not a modifier that can be removed, but rather a new object created based on the old object.
i found the best Solution .
Which is go to the Cure Editor and open it. you will find on the Right Side Object (Boolean or Proboolean).
select it and press on the Box 001 (The Element that u were Subtracting ur main object from)
Then Right Click on it and press press Copy.
Then press on the Object (Boolean ) again and right Click then Paste .
U will see in the Properties that ur Boolean Modifier was Deleted .
This is the Right Solution .
let me know if anything was unclear for u
