3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How to remove delet D5 Convert
4 REPLIES 4
M2Project
2880 Views, 4 Replies
How to remove delet plugin and script D5 Convert
please help.
Not work
C:\Users\***\AppData\Local\Autodesk\3dsMax\2021 - 64bit\ENU...
4 REPLIES 4
Libei.Wang
in reply to: M2Project
Hello @M2Project ,
If your plugin is installed from an installer, you can usually uninstall it from Control Panel, Programs and Features.  Otherwise, it can be in C:\Users\***\AppData\Roaming\Autodesk\ApplicationPlugins folder.
Cheers,
Libei
Libei Wang
Sr QA Analyst for 3ds Max
jrtayo
Even if I delete the files in the AppData folder it still is showing... any other way to remove this?
Cortamia
Uninstall D5 Convert 3dsMax
1. https://forum.d5render.com/t/workflow-d5-converter-3ds-max/2736
2. download and instal D5CCleanUpTool_Signed.exe.zip
After the download is complete, double-click the .exe file and click Next to uninstall D5 Converter-3Ds Max
3. Clear
jrtayo
in reply to: Cortamia
Thank you it helped a lot!
