how to get viewport color to match layer color after applying material
hi, i'm new to 3dsmax and just made a model with several layers and the viewport shows the color of the layer the object is in, which is what i want
then i started applying materials to some objects an the object in the viewport color changed to the material
but now i want it back to the layer color, but i want to keep the material for rendering
i can't figure out how to get the viewport to display layer color again
thanks
10DSpace
@Anonymous
There may be some confusion about terminology here, but I will address what I think you mean which is how to toggle between the display in the viewport of an object's color and it's material once it has an assigned material.  There is a toggle to do this in the display menu:
The toggle is for the entire scene and not just the selected object.
Regarding terminology, Layer Explorer shows in the Color column, the color of the individual objects in a layer as well as the layer color.  These can be set separately.  Hope this is clear.
Hello~ This Script May Help you
Copy The code Below into Text then Change the Suffix type to    .ms       (Max Script)
Then Drag it into  3DSMax and Release
it will display a Dialog named "LayerManager" includ 3 button
1 "DeleteEmptyLayer" Used for Old Version
2 Select the Other Objects in the Same Layer with the Object You're Selecting
if Objects You're Selecting is in two or more Different Layers . They will Select All of them too
3 This is your wanted
Select the Object you want to Turn the Wire Color as LayerColor
Then Click the 3rd Button , Turn is On the Function Will Activate
Of Cause , to get the Final effect you want ,you need swich the Display Mode  to Object Color as the Bro in 2 Level said.
rollout ET_LayerM "图层管理" width:114 height:70
	local T_SelArray = #()
	button DEmptyLayer "删除空图层" pos:[2,2] width:75 height:20 toolTip:"快速清理空图层\n右键:可将清理空图层加入右键菜单图层"
	button SelectLayerByNow "全选图层包含物体" pos:[2,24] width:110 height:20 toolTip:"按当前选择物体全选其所在图层的所有物体"
	checkbutton SwicthColorByLayer "切换图层线框色" pos:[2,46] width:95 height:20 toolTip:"将物体的线框色转为所属图层的颜色\n右键:随机图层线框色"
	on ET_LayerM open do
		T_SelArray = selection as Array
		for i in selection do
			if SwicthColorByLayer.state == on then
				i.colorByLayer = true
				T_SelArray = #()
				append T_SelArray i
			else
				i.colorByLayer = false
				T_SelArray = #()
				append T_SelArray i
	on ET_LayerM close do
		for i in T_SelArray do i.colorByLayer = false
	on DEmptyLayer pressed do
		ET_DeleteEmptyLayer()
	on DEmptyLayer rightClick do
		AddItemToQuadMenu (#nonePressed) "Default Viewport Quad" 1 "ET_DEmptyLayer" "ET_Tool" 7
	on SelectLayerByNow pressed do
		if selection != undefined do
				local S1 = i.layer.name
				local S2 = LayerManager.getLayerFromName S1
				S2.select on
	on SwicthColorByLayer changed state do
		T_SelArray = #()
				T_SelArray = #()
				append T_SelArray i
			else
				T_SelArray = #()
				append T_SelArray i
	on SwicthColorByLayer rightclick do
		for i = 0 to layerManager.count-1 do
			nowLayer = layerManager.getLayer i
			nowLayer.wireColor = color (random 60 240) (random 60 240) (random 60 240)
			nowLayer.backfacecull = true
Createdialog ET_LayerM
that's exactly what i needed, thanks
