How to get the direction of an edge?
futengda
futengda
I'm using 3ds Max's `meshop.divideEdge` to split an edge, and the split ratio comes from calculating the edge's vector. This vector is determined by the two points A and B obtained via `meshop.getVertsFromEdge`. Therefore, the ratio I calculate matches the direction from A to B. However, since `getVertsFromEdge` returns a BitArray, the vertex IDs are always in ascending order. But the `divideEdge` method seems to use an edge direction that I can't determine to calculate the split position, which results in the `divideEdge` position being different from what I expected.
Therefore, I believe that only by knowing the true direction of the edge can I make the `divideEdge` function work as expected.
Diffus3d
You might want to post this in the programming subforum, seems pretty specific.  This forum is mostly general usage, you probably won't get the same folks looking at your post here.
Best Regards,
futengda
