How to get the direction of an edge?
futengda
futengda
I'm using 3ds Max's `meshop.divideEdge` to split an edge, and the split ratio comes from calculating the edge's vector. This vector is determined by the two points A and B obtained via `meshop.getVertsFromEdge`. Therefore, the ratio I calculate matches the direction from A to B. However, since `getVertsFromEdge` returns a BitArray, the vertex IDs are always in ascending order. But the `divideEdge` method seems to use an edge direction that I can't determine to calculate the split position, which results in the `divideEdge` position being different from what I expected.
Therefore, I believe that only by knowing the true direction of the edge can I make the `divideEdge` function work as expected.
denisT.MaxDoctor
you need edge vertices in the direction order:
--> get face index by edge index:
face = (edge - 1) / 3 + 1
--> get edge index in face:
n = (mod (edge - 1) 3) + 1
-- get edge verts:
fn getMeshEdgeOrderedVerts mesh edge =
	face_verts = getface mesh face
	edge_verts = case n of
			1: [face_verts[1], face_verts[2]]
			2: [face_verts[2], face_verts[3]]
	  default: [face_verts[3], face_verts[1]]
futengda
you are awesome!
