How to disable start-up dialogue unit mismatch, or missing map ?
Waseem_Dabbas
Waseem_Dabbas
Is there any way I can disable unit mismatch, or missing map window dialogue at the start-up of 3ds max?
irishman_team_kilber
you can rename the 3dsmax.ini but i would not touch this unless you know what you are doing here is a thread see if it helps https://forums.autodesk.com/t5/3ds-max-forum/units-mismatch-popup-disabled/td-p/4027680
just use the relink bitmap scirpt to link the maps back to the material editor https://apps.autodesk.com/3DSMAX/en/Detail/Index?id=2039551202535585769&appLang=en&os=Win64
Waseem_Dabbas
Thank you for the answer, but I couldn't find any line in the 3dsmax.ini that indicate to "missing external files" dialog box, Any Idea?
5vil
To bypass those dialog, you can download attached file, extract it and put this maxscript into Max startup folder. Anyway you are on 3ds Max 2020, I assume? The attached script should work regardless.
There's also something similar that works for scene with xref here:
scriptspot(dot)com/3ds-max/scripts/silentium
