Hi guys, i'm completely new to 3DS Max software. I am using 3Ds MAx 2012. I have a model. Is it possible to DELETE the key frames and change the animation. When i created another new object, it allowed me to delete key frames, but not this one. One more thing: There are no red bars in the time slider for me to edit/ delete. When i right click on the time slider, 3 things pop up:
- filter
-configure
-go to time
The "Delete" option is blanked out?! Any help would be appreciatied! Thanks!!
Below is an attachment.
Looks like you have nothing selected in your scene.
I assume it's the dinosaur's walk or something similar you'd want to remove / adjust?
To do so, select all the bones in your scene and the keyframes should appear in the timeline. From there you should be able to select and delete them.
