How to create a high res game asset in 3DS Max.
Screenshot_7.jpgIf anyone call tell me how to make this top white part..that would be great...if it's a video that will be very helpful to me 🙂
Your post subject line has been edited by @hagen.deloss: Help with this model
irishman_team_kilber
you can select the same about of Polygons on the front of the model and the ones on the top and then under edit geometry in Polygon selection. You can click the deattach tick/check the box deattch as clone, this will clone the Polygon and keep the same Polygon on the original model that is not the best way to do it. i am not sure how you are gonna thinken it up if you add a shell that will look wrong i think
This is not the best way of modeling the top part of the model maybe someone else has some ideas
hagen.deloss
Hi @Anonymous
Great to hear from you on the forums! That looks like a 3D game asset with a normal map applied along with a nice texture map.
The game asset pipeline utilizes a lot of tools in 3DS Max, I found a pretty straightforward breakdown of how to start that process, and tips and tricks to be aware of along the way! here are the videos.
I hope this helps, and feel free to post back on the forums with any other specific questions on the tools within 3DS Max used in this process.
Talk to you soon 😄
Please select the Accept as Solution button if a post solves your issue or answers your question.
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
Hi @Anonymous
I wanted to check back and see if a post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process 😄
Hagen Deloss
