3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
How to change Field of View with numeric value, Rendering Method Panel missing.
2 REPLIES 2
600 Views, 2 Replies
I'm trying to find the Rendering Method Panel under the Configure Viewports menu to manually reset my Field of View to 45. However, that panel is missing.
I am using the Nitrous Direct 3D 11 driver on my viewports. According to the documentation found Direct3D drivers should still show the Rendering Options tab to pop up.
Is there any way around to get to introduce the Field of View value manually or at least rest it to 45 without resetting the whole preferences?
2 REPLIES 2
miledrizk
This setting is in the Per-View Preferences
miledrizk@gmail.com
3DS Max 2021, V-Ray 5.2
3DS Max user since 2003 (3DS Max 7)
V-Ray user since 2008 (V-Ray 1.47)
My YouTube Channel http//www.youtube.com/c/MiledRizk
in reply to: miledrizk
Thanks so much for that Miledrizk.
I can believe I was just right there and I couldn't find it after going over several forums and google search.
Thanks again.
