I was wondering what the process was for adding to an editable spline or poly? If for example I created a shape, but then wanted to - for example - add a section to the side of it, how could I do this without splitting existing faces/segments and manipulating them? Would this all be done with shape boolean, and then converting them to editable again?
If for example I drew a circle, and then wanted to have a rectangle protruding out the side of it.
Solved by irishman_team_kilber. Go to Solution.
use the boolean tool https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/3DSMa...l
or the shape merge tool https://knowledge.autodesk.com/support/3ds-max/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/3DSMa...
is this what you mean???
