How Ambient Occlusion works?
jostroopers
jostroopers
Hello
I am exploring Ambient Occlusion.
Now I have the idea that there are two ways to apply AO.
As an AO pass and with your material.
As an AO pass I think it goes via your render elements by adding VrayExtratex and adding the texture image VrayDirt.
The other way if you use an ambient occlusion Vray bitmap together with an albedo map linked with a composite to your diffuse slot in your VrayMtl.
But what is the difference then?
Is it so that the AO pass uses your entire scene?
And if you link it to your material that it is only applied to that material?
I watched several videos but find it confusing when to use the render element or a bitmap in your VrayMtL.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
Diffus3d
You got the gist of it.  But in Vray, there are 3 ways.  You can also just turn on AO in the GI-> Advanced settings, but by default I don't think it separates it from the diffuse.  (though it might these days, depending on your Vray version.)  However, it works properly with transparent objects and is faster than material level overrides.  I usually crank it to 10 feet and move on.
There are a couple things you also need to consider though.  First, transparent objects don't collect AO.  So, if you're doing a scene wide pass with ExtraTex you need to hide transparent objects, which means you're rendering the scene twice even if you're using the ExtraTex.  (Still, often faster.  I've found it's better to apply the Vray dirt to the color channel of a light material as the AO pass using global material override instead of ExtraTex.)
If you set the AO color on an object basis instead it may help make materials look a little more realistic because you don't have to use black.  You can use dark red, medium gray, etc.  Having them unique in that case is the draw.  However, it certainly makes it render slower to have more nodes in all your materials.  Any node can be instanced between materials, but if you're going to do that for all your materials then just use the scene wide pass.
Here's an example of a time when you might want to override it on a material level.  Let's say you have to do a render of a shoe wall.  Generally speaking, shoes connect to the wall through slats that sort of hook in.  Depending on the size of the scene, the light may not find the details in the slats very well.  A little vray dirt can make them pop out and also help the light to not bounce as much in there as the diffuse is dark with then lowers the light energy a bit.  (no more glowing edges, well, sometimes.)
Last, when you comp your AO back onto your render, remember... multiply at about 35% opacity.  Not 100%.  If you use the GI settings AO, it's all done for you physically correct.  Any other implementation is not technically correct, but still looks good.
Best Regards,
AJ
jostroopers
Thanks for your response, Alfred.
For now I create all my maps in Shader Map and then load them with Material Texture Loader.
That also includes Albedo and AO which then will be linked with a composite to VRayMtl.
If I do this with all materials, is it still wise to apply AO in a different way in the scene?
I don't think it's a problem that a scene has to render longer, I have a good computer system.
I think it doesn't make sense to use both, both in your material and in the scene via a render element for example, right!
I'll have to do some tests here to see if I put AO in the material or process an AO in the scene.
Mvg Jos
Diffus3d
Yeah, don't use both for everything.  Best bet is to leave them out of materials and just use the GI settings AO and let Vray take care of it.
Best Regards,
jostroopers
Thanks Alfred.
Best Regards
Mvg Jos
Diffus3d
Happy to help, post back if you have weirdness.
Best Regards,
