Announcements
Hey Bro !! How to random color by poly element via Proxy?
[url=http://sagame1678.com/][color=white][size=1pt][b]baover[/b][/size][/color][/url]
I have this alembic loaded via vrayProxy with 5 Material IDs. My question is, on the polys with mat ID 2, how can i random color those with ID 2? I tried every possibility with vraymultisubtex and nothing works in this case. If only we had a "random by element" that would work in this case Any help?
thankyou for reading
[url=https://baover-th.com/sagame/][color=white][size=1pt][b]sagame[/b][/size][/color][/url]
10DSpace
Hi @Anonymous
I think you could do this pretty easily with maxscript.  I have not worked with vray proxys or alembic, but as an example of how to assign random color to a particular group of polys of material ID=2 , the following line works on an object with a multi-subobject material assigned with standard type sub-materials.
$.material[2].diffuse = random (color 0 0 0) (color 255 255 255)
You could use the Macrorecorder to find out the syntax for how to access the diffuse slot of your proxy material and then adapt the maxscript accordingly.  Hope this helps.
