Help: Warning Loading Plug-in DLL
siddharthpatel1512
Observer Observer
Message 1 of 12
siddharthpatel1512
Observer
Observer
This error keeps coming up since yesterday every time I open max. I haven't found any solution so far on the net. I can't find the file either (this might be cos I'm looking in the wrong place).
Replies (11)
Message 2 of 12
CAMedeck
It looks like 3ds Max is reading a second instance of the Shader.  Have you added any new user paths for plugins lately?  I remember seeing a similar error when copying a plugin DLL into a plugin directory when the DLL was already in another directory, hence the 'duplicate id' portion of the error.
Chris Medeck
Message 3 of 12
jon.bell
Hi @siddharthpatel1512 ,
Just wanted to check in to see if you were still receiving this error message, and if you had been able to remove it by editing your plug-in paths (or removing the duplicated .dll file). Please let us know, and thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 4 of 12
I have installed 3ds max 2022 version 64 bit. Error loading plugin dll on boot. how do i fix
Message 5 of 12
jon.bell
Hi @Anonymous,
Could you please post a screenshot of the exact error message you're seeing when launching 3ds Max 2022? That will help us diagnose this better. Thanks!
Jon A. Bell
Message 6 of 12
Hello
I have the same problem. Previously, everything worked great and suddenly this message popped up ... I uninstalled and installed the program again, but the message is still there.1a.jpg
Message 7 of 12
jon.bell
Hi @Anonymous and @siddharthpatel1512 ,
Your Security Tools are showing that they need to be updated, so I would definitely download and install the newest version from the Autodesk App Store, then seeing if this error goes away.
If not, I would suggest resetting your 3ds Max preferences to make sure there are no corrupted settings and to remove duplicated plug-in paths from your 3dsmax.ini file. Please let us know if this helps!
Jon A. Bell
Message 8 of 12
y.garciaC4Z2J
Observer
Observer
Hello! Hope you're doing well. The same issue happened to me and I applied the reset and it fixed it! Hopefully, it won't happen again. 🙂 I am very thankful for your advice. 🙂 Have a great day.
Message 9 of 12
jon.bell
Hi @y.garciaC4Z2J, @siddharthpatel1512, @Anonymous, and @Anonymous,
I hope you're doing well!
I just wanted to note that these .dll warnings are usually caused by having duplicate plug-in .dlls in different folders.
My recommendation is to reset your 3ds Max user preferences, and if that doesn't fix the issue, open Windows Explorer and do a search on the plugin name.
If you find two instances of the same plugin in different folders, rename the .dll extension to .bak (or similar), then restart 3ds Max and see if the issue has gone away. Thanks!
Jon A. Bell
Message 10 of 12
a_hlavatova
Hi, when I want to open 3ds max it shows that corona max plugins dll failure and corona doesnt appear. Someone know how to fix that?
Message 11 of 12
miauuuu
Reinstall Corona.
https://miauu-maxscript.com/
Message 12 of 12
a_hlavatova
I did that and the it showing the same message
