Hi there; I was advised on Twitter to post my query about key binding in 3DSMax 2017 here. This is also similar to an existing post from 2011:
https://forums.autodesk.com/t5/3ds-max-forum/key-binding-advice-needed/m-p/4225163#M68715
Because my left arm is currently in a cast, I don't have the dexterity needed to use a keyboard and mouse. To get around this, I would like to bind mouse button 4 to rotate/orbit. Unfortunately, these buttons (4+5) do not seem to be recognised. I tried binding LMB+RMB but the key assign area just flicks between the two buttons, haha.
If anyone could advise on how I could bind my surplus mouse buttons to the basic functions I would appreciate your insight.
Thank you 😃
Solved by Alfred.DeFlaminis. Go to Solution.
Thank you for your speedy reply.
It's an interesting work around, and I can see it can be put to great use. Unfortunately it's not an answer to the query posed, being that of whether or not the function can be bound to the mouse (in some way).
Again, thank you for sharing the link.
Hello @Anonymous and welcome to the community,
As far as I know, there's no native way to do this in Max because it does't really recognize Mouse4. However, you can pull it off with a neat little program called Auto Hotkey. It's a bit tricky to use at first, but it should be able to do this. I use it a lot of games that won't let me bind keys to the numpad. You basically need to bind Mouse 4 as a keypress of Alt+MMB. I can't do any support for Auto Hotkey since it's not an Autodesk product, but it's the best workaround I can think of. It's not too hard to learn for simple stuff like this.
Best Regards,
Alfred (AJ) DeFlaminis
3ds Max Technical Support Specialist
Autodesk Here to Help | View Max Tips/Tricks | My Screencasts | Autodesk Virtual Agent | How To Reset User Settings | Change Display Drivers in Max | Feature Request Board | Installation and Licensing Forum | 3ds Max Certified Hardware | Network Rendering Troubleshooting Guide
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
