Having problem with snap tool
Message 1 of 11
Hello, I am having problem while using snap tool. I've tried to explain my problem on youtube video but I spoke Turkish language on video. I apologize for my spelling mistakes.
By the way I have already did full uninstall program and tried to fresh start but it didnt work.
Also all Snap Tool properties are set as default.
Replies (10)
Message 2 of 11
irishman_team_kilber
what are you snapping too? if you left or right click on the snaps tool then it will bring up your snaps setting box i think by default it snaps to grid points or vertex so you may need to change that if you have not already done so
Message 3 of 11
These are my snap tool settings, its all set as default already. Still having problem. 😞
Message 4 of 11
Change your snaps setting box from vertex to grid points. close that down. then enable the snaps then use the auto grid to draw a small box on the bigger one.
i think that is what your trying to do
Message 5 of 11
Actually thats not the problem, I want to catch box from corner and create new one on to this. But when i try do that while using snap (vertex) tool it creates square another way. With Grid Point tool I cannot catch box from corner.
Message 6 of 11
The line of vertices does not snap to each other on the same line.
selec this line click right botton - Convert the line to editable spline.
Message 7 of 11
krystian.slusarz
Yeah it works in a weird way. I'm not sure if this is a new bug, or something that've been there forever.
My only solution for it, is using autogrid when creating new box and/or selecting "face" in snap options beside vertex
Message 8 of 11
jon.bell
Hi @Anonymous ,
I just wanted to check back with you to see if Krystian's suggestions worked for you, and if you were still having these issues. Could you please let us know? Thanks!
Jon A. Bell
Senior Technical Support Specialist, 3ds Max
Message 9 of 11
tenkara_fan1337
Community Visitor
Community Visitor
I'm also having a problem with the 3d snap tool with only vertex option selected.
Message 10 of 11
jon.bell
Hi @tenkara_fan1337,
I just wanted to revive this thread to see if you were still having these issues with Snap, or if they'd been resolved. Did you try toggling between 2.5D and 3D snap mode to see if this made a difference with Vertex Snaps?
Please let us know, and we hope to hear from you soon!
Jon A. Bell
Message 11 of 11
mahesh.kp
Community Visitor
Community Visitor
it is working ony for 3D snap .! not for 2.5 D snap and 2.D
