3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
green screen
2 REPLIES 2
510 Views, 2 Replies
green screen
I have a few green screen videos. Is there a way to import them into 3ds max 2015 and take away the green backround, then lay it over the 3d world?
Thanks!
2 REPLIES 2
CAMedeck
That's usually something reserved for post production using Premiere, After Effects, etc.
I can't think of a way to key out a color in 3ds Max.  Maybe it can be scripted or something?  May take a custom shader... I found a plugin for Max 6 that does this, but I doubt it would work = http://scripts.breidt.net/chroma.html  Maybe more searching could turn up a useable solution.
What render engine are you using?
Chris Medeck
iadproductions
in reply to: CAMedeck
You can also try Autodesk Composite available at the Exchange Apps site.
http://apps.exchange.autodesk.com/MAYA/en/Detail/Index?id=appstore.exchange.autodesk.com%3aautodeskc...
Mastering Autodesk 3ds Max 2013
http://www.amazon.com/Mastering-Autodesk-3ds-Max-2013/dp/1118129717/ref=zg_bs_4135_2
