A new problem I am having lately is when I want to import geometry from one Max file to another it comes in very big, distorted and squashed, backwards and not even at 0,0,0.
It happened with Max 2020 about 2 months ago when importing, and had never had that happen before 5 years using Max 2020. I am unable to use that version and am using Max 2024 and having the same issue. Using Windows 10 64bit pro.
File I am importing from is on the left and Imported (Merged) geometry is on the right. I rotated the bumper 180 degrees and moved in front of the other car to show how it is distorting.
I have been using Max for 20 years now and have never had this problem. The units are set up exactly the same in both files. This really helps speed up workflow when you can import geometry from another file and not have to completely remodel everything and saves weeks of time. Has anyone else had this issue and know a fix for this. Would really appreciate feedback and help. Thank you.
