Function for undefined
Message 1 of 9
http://prntscr.com/dg8uhg , http://prntscr.com/dg8uuv i need some help, someone know how can i solve this? thanx!
Replies (8)
Message 2 of 9
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
Can you please list your currently installed plugins for me?  Scripts?  Thanks very much!
Best Regards,
Message 3 of 9
Hey! thx for your answer i have this 3 scripts installed 1. http://www.scriptspot.com/3ds-max/scripts/vraymtlconverter-v2-5
2. http://www.scriptspot.com/3ds-max/scripts/vraymtlconverter-v2-5
3. http://www.scriptspot.com/3ds-max/scripts/steamroller
i got them from this tutorial https://www.youtube.com/watch?v=iBww9A5FHLo&t=464s
the first script is not working when i try to install it i have this 2 errors
http://prntscr.com/dg8uhg , http://prntscr.com/dg8uuv , http://prntscr.com/dg939h maybe this could help too
im from romania, i want to start use 3ds.max , ue4 and sketchup to make this https://www.youtube.com/watch?v=bYbuMthPKss for virtual reality, i-ll be the only one in my country and i could gain some money 🙂 it-s a good project! , and i need to learn 3ds.max ... i'm trying so hard ...
Message 4 of 9
Alfred.DeFlaminis
Hello @Anonymous,
Thank you for the screenshots and extra information.  I believe the problem here is that the scripts were made for a different version of 3ds Max than you are using.  I'll do by best to detail this below.
VrayMtlConverter:  This is a great script I remember from my time doing viz work, but the problem is that it's only supported up to  3ds Max 2012 and for Vray versions up to 2.X.  (So the current version 3 isn't supported based on the documentation on scriptspot.)
You might try the script called MultyConverter to see if it works in 2015 or if you are using Vray and just need to convert to Vray Materials, you can use the Vray Scene Converter that exists as part of your standard installation in the right click quad menu.  Or, you can appeal to the author of the script to update it for 2015.
If you have Max questions in general, I'm here and happy to help.  I can help find solutions for your problems or offer workarounds if things aren't working.  Don't be shy to post here, I'll do whatever I can to help.  All that being said, what is it that you are looking to do with the scripts?  Maybe I can help find another way.  Let's work together to find a way to make this happen for you.
Best Regards,
Message 5 of 9
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?  Any luck with the Vray Scene Converter?
Best Regards,
Message 6 of 9
Yes man, problem solved, first of all I should install the v-ray plugin and after the that the script, I forgot about vray plugin, thx for your help! If something else is happen I will let you know, thanks for your time, help and patience! Wish you a good day!
Trimis de pe smartphone-ul meu Samsung Galaxy.
Message 7 of 9
I'm new with 3ds.max and now I learn a lot of things, if there is something else that I will don't know, I will write you a msg, thank you for your time and consideration! You're the best!
Message 8 of 9
Your last post help me a lot, to do more research and find out where the problem was!
Message 9 of 9
Alfred.DeFlaminis
Thank you for the very kind words @Anonymous!  I'm super excited that your problem is worked out and I really appreciate that you took the time to update the thread.  Smiley LOL   You are greatly appreciated and have a happy holidays!
Best Regards,
