Fixing a DWG/DXF Import: broken poly
Judith.Hageman
Judith.Hageman
I am doing my homework, reading and trying, but I am a bit stuck in translating at the moment.
I'm trying to download a mechanical design as a step file, and I am getting very pleased with the result after 9 attempts, but...
before continuing with attempt no 10 I would like to find out which option is responsible for this problem: Import-P&G-Demulsifier-20170330-T9-result.JPG
These are the options I used. Can someone please put me in the right direction? I will do the rest of the work myself.
I am sure there are modifiers in Max to fix these things, but my goal is to import without using those at this point.
Import-P&G-Demulsifier-20170330-T8-step-1.JPGImport-P&G-Demulsifier-20170330-T9-step-2.JPG
Thanks!
Judith
Judith.Hageman
Never mind, fixed it...
Alfred.DeFlaminis
Wow Judith, you're fast!  Fixed before I could even get here.  What did you do to fix it, please?  In case someone else has the same problem.
Thanks and best regards!
Judith.Hageman
Hi @Alfred.DeFlaminis,
Sorry, I am not the most patient person, I mostly keep busy, since the answer to my question could be found somewhere. Smiley Embarassed
Kept looking on Google, found a small article with different settings, although is was meant for 100% AutoCAD Import. Changed it a bit, since I don't use layers, it worked. I might need to use a TurboSmooth though to really get the cylinder shapes smoothly rounded.
Here are the settings, but be aware: if you do use original AutoCAD change the Derive AutoCAD Primitives by: Entity option to one of the two layer-choices, and select the layers in the second Tab!!! I skipped that one.
Import-P&G-Demulsifier-20170330-T10-step-1.JPGImport-P&G-Demulsifier-20170330-T10-step-2.JPGImport-P&G-Demulsifier-20170330-T10-result.JPG
Alfred.DeFlaminis
Thank you for sharing the information for the next person who searches for this answer @Judith.Hageman!  That's nice of you!
Best Regards,
