fill holes using cap hole give unwanted face in 3ds max
Hello Guys,
I need help on this model. i tried fill holes using cap hole but it generate unwanted mesh in the circle area. So my question is how to manually remove it?
Your post subject line has been edited by @hagen.deloss : fill holes using cap hole give unwanted face
hagen.deloss
Hello @Anonymous
Thanks for posting your question to the 3DS Max Forums! What version of 3DS Max are you using? From the look of the hard edges of the mesh, you are going to have to hand model those faces back into the mesh, I suggest converting your object into a Poly, and use a combination of the bridge tool and the swift loop also merge vertex tool can come in handy. Here is a video of some other modeling techniques.
If you have any further questions, I'm more then happy to help! Also a screenshot of your mesh with wireframe preview on top would be awesome. You can do that by clicking on default shading in your viewport and navigating to the display selected option and clicking Display Selected with Edged Faces.Screenshot (32).png
I hope this helps, talk to you soon!
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
hagen.deloss
Hello @Anonymous
I wanted to check back and see if my post helped you with your problem. It would be super helpful if you could add a post with how you decide to proceed, and your results. That way other Community members can benefit from your process
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
Hagen Deloss
jibijib
If it is filling the hole beyond the hole you are wanting to fill, it's because it isn't capped correctly.
You need to make sure all vertices are welded, otherwise it will try to fill the entire mesh.
You can select 'border' in Editable Poly, and select all and it will show you all the unwelded vertices on the mesh (by a big red edge line).
i still have no idea how to do it but i think i skip it for now
