File save error
File save error
Message 1 of 11
File save error
Hi
Everything normal in my 3ds Max, excluding one thing.
Program get an error message if i save as archive.
Error message is:
File save error
File archive failed ( code 1 )
My system is windows 7 64x
a sufficient hardware is available
Accepted solutions (3)
Replies (10)
Message 2 of 11
If someone know that error how to fix, tell me please.
Message 3 of 11
Hi, if you create a new scene, probably you won't have this problem, if this is the case, probably the solution is just below.
i think this problem is related to your assets. Check your asset (shift+t) and make sure you don't have the same maps pointing to multiple folders. If it's the case, repath those maps to the same sources folder.
Also, check your save path in render settings, common tab, render output and make sure the path is correct, if used.
Message 4 of 11
Hi
Same Error if i greate new project.
I search it on google, everyone saying about assets, but same in new ( empty ) scene.
Message 5 of 11
Any solution ? Someone ?
Message 6 of 11
ur problum is solved or??
i m facing same problum if u found solution plz help me too.
regards
Rehan Khan
Message 7 of 11
Alfred.DeFlaminis
Hello @Anonymous and @Anonymous and welcome to the community,
Would you please check out this article for more information about this and try those suggestions for me?  Thanks very much!
Best Regards,
Message 8 of 11
Alfred.DeFlaminis
Hello @Anonymous, @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
Message 9 of 11
Dear Sir,
I have  faced the same problem
archive save error code -1
there are some administrator policies which are sometimes blocked by antivirus or by company to secure from virus.
Batch and zip extension block from GP (group policy)
Message 10 of 11
I have solved this issue as mentioned in my previous comments that some software been blocked by antivirus or by company policies to secure the system from attacking virus.
when you click on save as >>>> archive >>> then select any location where you want to save >> press save
after this it gives you an error
File save error
that's because of cmd.exe , which is sometimes blocked and creation process of archive file based on  cmd.exe software as I showed in below images, so if its blocked it will give you the same error as mentioned above Untitled-1.jpg2222.jpg
I think this will help you.
Message 11 of 11
how to resolve  this issue please let us know
