file save as pdf
file save as pdf
file save as pdf
Hello guys ! when I save file on 3ds it save it as a .pdf file and not as 3dsmax file .
what should I do ?
thanks
rendermaster
i guess its still 3ds max files but the properties were change.....to correct it, right click on your 3ds max files, then select properties. On properties window that will pop-up, press the button CHANGE  and look for 3ds max application
Ronel Katigbak Pabico
3D Generalist / Animator / Renderer/ Graphics Designer
Autodesk Student Ambassador Platinum
YouTube Channel l Linked l Facebook l Blogs
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
That's a bizarre issue no doubt about it.  The easiest course of action would be to make sure to add '.max' to the end of your file names.  So "MyScene_01" becomes "MyScene_01.max".  That should override the Save As type in the dialog for any windows application from my experience.
Somewhere the file type associations may have broken for PDF or Max on your system.  You could try to hold down shift, right click a Max file, select "Open With" -> Choose Default Program -> and select 3ds max.  Make sure "always use the selected program to open this type of file" is checked and that should update your associations.
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
when im going to save my project on 3d max i put render then im going to save my render then appear some choices to save. (for example) jpg, exr, png..........and then i put save (render setup i choice size 1920x1080 ). Then i open my photoshop and i look the image resolution and i see. 1920x1080 and the resolution is 72 pixels/ per inches and i want 300 pixels/per inces. any solution how to do 300 resolution for photoshop png  or jpg files?
