exporting loses color
This widget could not be displayed.
hi, im new to 3ds max, id like to create a 3d model for Augment but when i export my 3d object in .dae i lose the color. all i did was create and cube, change its color but lose the color, why is that and how can i keep the color when exporting .dae
darawork
Exporting to Augment with textures requires you to have 'Standard' materials applied to your objects.
Simply changing the vertex colour of objects will not translate across the two packages.
http://www.augment.com/help/requirements-and-limitations/#materials
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
oh thank you! ill do a tutorial on adding standard materials 🙂 thanks!
