Recently I bought a nice 3d model. This now appears to be a 3ds max file.
Because I work with artlantis, I cannot import this file.
Is there anyone here who can export my 3ds max file to fbx? Preferably with the layer structure so that I can also add the materials.
Thank you very much.
Simon
Solved by spacefrog_. Go to Solution.
Can you post a link to the Max file or send me a PM?
I would export it for you to fbx
BTW:
Not sure whether the 3ds max layer structure is kept intact with the FBX , but i think your concern is mainly about the the object structure being kept intact and not merge them or something, right ?
Hereby a wetransfer link with the 3d model of the object to convert to fbx.
Simon Vandendriessche
I had a look at the scene: the material setup is pretty complex and i doubt that i can transfer all of them over to FBX without much effort ( which i currently do not have time for sorry )
Nevertheless, here's the converted file hope it works for you
Hi, could someone here help me to convert 2 objects (3dsmax files) to fbx?
You would help me a lot with it.
And of course you can use these objects yourself.
Send it
Thanks for your comment. If it would be possible to convert this 3dmax file to fbx that would be great.
Thank you in advance.
Grts Simon
