While 2GB is the absolute minimum, remember that the OS can take nearly a GB of that leaving just 1GB for Max. Theoretically enough for it to run, but probably not to do anything useful with it.
Might be time to consider a new system - 64bit with at least 4GB and perferably 8, and a 64bit OS.
I got 6 pages of results searching for 0x0000006 - hence the multiple possibilities I gave earlier. I would definitely run at least 2 different virus scanners (reputable ones!), possibly a memory tester in case the RAM has gone bad, make sure all drivers are up to date. Oh, and try the "normal" nVidia drivers if you have any "special" ones installed, just in case.
This is almost certainly a system issue rather then one with Max, as such it's a bit beyond the scope of these forums.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
