3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Error importing USD file: “USD does not support unicode characters in filepath, please remove these characters.”
2 REPLIES 2
steven
216 Views, 2 Replies
HI,
A client send me Blender 3D files. I need to importthem file into 3DSmax. I try USD export from blender, but I get this error message when importing the USD file in 3dsMAX:
I tried differents option in the Blender exporter window, got the same message every time.
Importing the USD file back in Blender work fine. So I assume this is a 3dsMAX importing bug.
Is there a workaround?
ArteMAX.
2 REPLIES 2
Max.macmillan
in reply to: steven
Hello Steven,
The error you're experiencing suggests that the file path to your .usd file (or .usd filename itself) on your local disk uses Unicode characters to describe the path. USD Expects alphanumeric values. A-Z, 0-9, underscores and spaces to describe filepaths to USD content. You may need to rename your .usd file and doublecheck your filepath for the unsupported unicode characters to continue.
I hope that helps!
Max MacMillan
max.macmillan@autodesk.com
3D QA Analyst
steven
in reply to: Max.macmillan
Thanks Max,
It works now.
Steven
