i have problem with 3ds max 2023 because when i open 3ds max 2023 i have an error 1114
i hope you have idea to ride of this error
i have the same problem in pc
if you are using laptop or PC that have 2 graphic cards you need to set high performance graphic for 3ds max ...
you can find a lot of solution by searching in internet
BUT
if you are using Pc with one graphic card There is no solution And I have the same problem
i have the same problem and i solve this problem by changing windows to windows enterprise version
you should change windows to enterprise version
