Editing Lofts: Situation Gone from Good to Bad to Worst
- Mute
- Permalink
- Report
I am a teacher working on a tutorial I wrote for editing lofts using Path Parameters. I create a loft using a rectangle as a shape and select a line to form a square post. To edit the post, under "Path Parameters" I set the "Path" to 20 (%). I used to click on the "Get Shape" icon (in "Path Parameters") and select a square. I would then set the "Path" to 20.5 and click on "Get Shape" and select a circle to begin substantially changing the shape of my loft.
But recently, I started failing to be able to select a shape. I could highlight the "Get Shape" icon but then could not select a shape. The arrow cursor would not change. This is the first kind of failure I began to experience.
Now, after I create the loft, then set the "Path" under "Path Parameters" to 20, the "Get Shape" icon remains grayed out. In other words, I am getting farther away from the success I used to have editing lofts and teaching students how to do it.
I would appreciate suggestions.
