Hi, good time; in 3dsmax 2018 Display unit isn't active, and I can't set the unit. How could I fix it?
Thanks For Your reply
Solved by erfan.azarin. Go to Solution.
Well, isn't the best solution, but if you rename your ENU folder, does it fix it?
Hi really thanks for your detailed answer surprisingly after I unchecked run as an administrator in 3ds max it was fixed
