display transform variable value - Script Controller
andrew_canfield
andrew_canfield
Hello
I'd like to check a calculation but not sure how to output the values to read them when using the Transform Script controller.
Regards
Andrew
leeminardi
I use the format statement.  Open the Scriptig Listener window and add the satement at the points where yo uwant to calculated values.   \n is used to start a new line.  For example,
Will show the following in the listener window.
If you want the transform of an object in your model then just select it and enter.
$.transform
lee.minardi
