Announcements
Display Script Operator in Pflow? How?
Can someone explain how to get the Display Script Operator in Pflow show a value? I tried using the default script operator and then tried copy/pasting the line from the max help on Display Script -- "pCont.particleFloat = length(pCont.particleSpeed)*4800" in numerous places in the script and it never worked.
I think your syntax doesn't read well by 3ds max, or it was error.
don't use syntax, if you don't know max script
use particle View.. 3ds max have alot stuffs for PF
goodluck !!!
Edited by
Discussion_Admin
The syntax is directly copied from the max help file so it should be correct.
I know maxscript to some extent --- but not as it relates to PFlow.  I wanted to experiment but I can't even get the Display Script to work.
OMG, there is so much BS and spam coming out of BlackParasite's derrière...
@Anonymous,
01) just create a Standard Flow for playing purposes
02) add a Script Operator to the bottom
03) add a Display Script to the bottom, set Show Script Data to Float
04) in Script Operator, Edit script
05) add the command
just below pCont.particleIndex = i
don't change anything else, unless you know what you are doing...otherwise, Oleg might kill you.
Now at this stage, you'd still see a bunch of ??? flying around...what's missing ? Love...ALOT of love !!!!
Well here's the secret ingredient, near the top, find the line pCont.useSpeed = true, copy and paste below it, then change it to
     pCont.useFloat = true
Why  ? because remember we set it to Float in step 03...
And there you are, do you feel like John Nash right now ?....oh yeah...did you subscribe to BlackParasite ? I'm sure he doesn't spam...noooooooo...
also if you want to see the particles fly out as per Standard Flow you can comment out the script like this:
    for i in 1 to count do
/*        if length(pCont.particleSpeed) > slowSpeed then -- slow it down
            pCont.particleSpeed -= dragCoef*timeDif*pCont.particleSpeed
        newLen = length(pCont.particleSpeed)
        if newLen > verySlowSpeed then
            pCont.particleSpeed = pCont.randDivergeVector(pCont.particleSpeed)(divAngle/(160*newLen))
        else
            pCont.particleSpeed = pCont.randDivergeVector(pCont.particleSpeed)(180.0)
        if length(pCont.particleSpeed) < 1.5*slowSpeed then
            if pCont.particleID < 50 then -- first 50 particles to left if slow enough
                pCont.particleSpeed += [-0.005*timeDif, 0, 0]
            else -- particles after 50 to right if slow enough
                pCont.particleSpeed += [0.005*timeDif, 0, 0]
So it doesn't follow the 'turb' in the supplied script, you can delete some more bits above it as well but I thought, nah...might as well leave it in there to play around with...
Thank you!
The useFloat was what I needed.  I think Adesk should mention that critical line in the docs for Display Script.
