3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
Disable clone pop-up in Edit Poly
6 REPLIES 6
office
2251 Views, 6 Replies
Is there a way to temporary disable the clone pop-up (SHIFT+DRAG) in Edit Poly/Editable Poly? I want to clone my meshes for a while and I KNOW that I don't want to detach them completely to separate objects. With so much cloning that I need to do, this pop-up really starts to irritate me.
Thanks in advance!
3ds Max subscription customer since 2010
| Max 2022.1 | AMD Threadripper 3970X 32-core | 64GB RAM | Nvidia GeForce GTX 1080 Ti FE 11GB | NVMe SSD Samsung 960 Pro | Win10 Pro x64 | Nvidia Driver 466.47
6 REPLIES 6
Alfred.DeFlaminis
in reply to: office
Hello @office,
Without scripting your own solution, there isn't a default method of disabling this.  If you're simply duplicating an element, maybe you could use an array or PFlow to scatter the objects separately and then attach them all at the end.
I did find this thread where JohnnyRandom wrote an .mcr but it's for an old version, deals with objects and not subobjects, and no longer evaluates correctly.  If you're a maxscripter, you may be able to tweak the code to make it work.  You may also try other script websites and see if a solution exists there.
Please hit the "Accept as Solution" button if my post fully solves your issue or answers your question. This lets me know that I was effective in helping you, and thank you for doing so.
Best Regards,
office
in reply to: Alfred.DeFlaminis
I hoped there was a built-in option somewhere but apparently not. Here's an idea for a new feature.
Thanks for the help anyway. I might take a look at Scriptspot.com or a similar site to check for a script.
Alfred.DeFlaminis
in reply to: office
Hello @office,
Sorry it didn't work out for you this time, but you can request a feature here and it will be voted on and possibly implemented in future versions.  The key here to keep your sanity might be doing it on the object level and then attaching.  I think you might check the site you mentioned, it has a good likelihood of having something you could use, and best of luck.
Best Regards,
office
Awesome, thanks for the suggestion. 🙂
It would evaluate correctly - but the forum migration screwed a few characters. Anyway, it's a replacement tool to be bound to a shortcut and wouldn't offer dragging the object to a new position, only duplicating it in place.
To answer the orginal question, this will confirm the dialog as soon as it appears:
try destroyDialog ::popupClose catch()
rollout popupClose "Popup Close" width:75
	checkButton chbAutoClose "AutoClose" checked:true
	global closeDetachPopup = fn closeDetachPopup =
		local hwnd = dialogMonitorOps.getWindowHandle()
		if UIAccessor.getWindowText hwnd == "Clone Part of Mesh" then
			UIAccessor.PressDefaultButton()
			true
		else false
	fn enableClosing =
		dialogMonitorOps.enabled = true
		dialogMonitorOps.interactive = false
		dialogMonitorOps.registerNotification ::closeDetachPopup id:#close_detach_popup
	fn disableClosing =
		dialogMonitorOps.unRegisterNotification id:#close_detach_popup
		dialogMonitorOps.enabled = false
	on chbAutoClose changed checked do
		if checked then enableClosing() else disableClosing()
	on popupClose open do enableClosing()
	on popupClose close do disableClosing()
createDialog popupClose
Bear in mind, that dialogMonitor prevents user interaction with ANY popup dialog, so if you want to open some settings dialog, material editor etc., uncheck the AutoClose button and check it only while you're detaching.
@Swordslayer, you have gone above and beyond here.  Thank you for posting this, this is really great.  Have a great day and thanks again.
Best Regards,
