Hi @Anonymous Welcome to Autodesk Community!
3ds Max and AutoCAD are two different programs. What are you trying to do in your assignment?
@Anonymous
It depends on your business plan. What industry is it? What exactly are you trying to create in the business plan?
I'd have to answer that it depends... Both Autocad and 3DS max can be used to 3D design a layout of a coffee shop.
Of course 3DS Max would be better as far as creating final renders, although I have seen some impressive work
done only with autocad. Do some research yourself and you will discover the pros and con's of each application.
Both AutoCAD and 3DSMAX are fairly complicated programs - they aren't the typical hardware store interior layout programs where you just drag'n'drop a few items to create images. If you aren't familiar with either program I would advise AGAINST using them for a school project, presumably on a deadline of a couple of months - learning to use them is a dedicated full-semester (at least) proposition. If you really, *really* want to do this check with the design/drafting department to see if they have some students there who would be willing to work up the models and renderings for you.
