Default Lights Follow View Angle toggle - script request
345243235
586 Visites
2 Réponses
Message 1 sur 3
345243235
I would like a 1-click command to toggle this feature (on/off), is it possible with MaxScript?
ps.this feature was removed in 3ds Max 2021, I am using 2020.
Thanks in advance!
0 J'aime
587 Visites
2 Réponses
Message 2 sur 3
spacefrog_
There WOULD be the following maxscript command to toggle that off
(NitrousGraphicsManager.GetActiveViewportSetting()).DefaultLightsFollowCamera=false
problem seems to be, that the functionality behind the mxs command seems to be broken
even after i assign false , the next call to the function ( without the assignement part) returns "true" .  I tested in Max 2021 and Max 2020 and while Max 2020 accepted and stuck to the "false" value , the light in the viewport still was view dependent.
So i suspect turning this option OFF has been non-working for some releases already, and Max 2021 simple reflects the correct internal state when using the mxs command
Josef Wienerroither
Software Developer & 3d Artist Hybrid
0 J'aime
Message 3 sur 3
345243235
Hey Spacefrog, thanks so much for the input! To be honest with you the main problem I'm having is that when I switch between shading styles and go back to "Performance" the Default Light is always unticked and I need to navigate to the Viewport and Settings Preference window to change it back.
Your command works! Can I ask where you found that line of code? because it doesn't appear in the MAXScript Listener when you tick/untick the checkbox in the settings window.
When I run the line with TRUE or FALSE it seems to work regardless, but are you saying it's impossible to create a toggle type script because of an internal error? obviously I can place each command as a single action on the toolbar, but a single ON/OFF toggle command would be brilliant.
0 J'aime
