公告
Customize user interface - mouse error
RenderQ
552 次查看
5 条回复
1 条消息(共 6 条)
RenderQ
When I do anything in the customize user interface and I want to close it I get a Mouse error - Can't write mouse.
I can just close that but it seems like a bug to me.
0 个赞
553 次查看
5 条回复
回复 (5)
2 条消息(共 6 条)
darawork
Which version of Max? And, do you have any 3rd party mouse software running that might be preventing access to rewriting mouse buttons?
Darawork
AutoDesk User
Windows 10/11, 3DS Max 2022/24, Revit 2022, AutoCad 2024, Dell Precision 5810/20, ASUS DIY, nVidia Quadro P5000/RTX 5000/GTX760
0 个赞
3 条消息(共 6 条)
RenderQ
I have 3ds Max 2024.2.1 Update and I don't think I have any except logitech options app for mx master 3 mouse.
PS: this happens without changing anything in the customize user interface, just open and close
0 个赞
4 条消息(共 6 条)
darawork
Ok,
Did you try the usual ENU renaming process? Copy your existing ENU folder, with Max closed, then restart Max.
"To reset the preferences manually (English-language versions), do the following:
  1. Ensure that 3ds Max is not running.
  2. Open Windows Explorer and make sure hidden files/folders are visible in Windows (see How to turn on hidden files and folders on Windows).
  3. Navigate to the following path:
    C:\Users\<username>\AppData\Local\Autodesk\3dsMax\20XX - 64bit\ENU
  4. Rename the ENU folder to ENU_old.
  5. Restart 3ds Max. When the program launches, it will create a new ENU folder with default startup settings.
To restore the old settings, delete the new ENU folder and rename the old folder back to ENU."
This process will allow you to check if something has become corrupted in your customisation folders, and it's not just a bug. If it was a bug there would be a lot of similar threads concerning this, I'd imagine.
Darawork
AutoDesk User
0 个赞
5 条消息(共 6 条)
Diffus3d
This also happens to me for like... 6 years on all versions.  What's weird is that the changes save and work ok, but that weird message always pops up.  I ignore it, but it's weird.
Best Regards,
6 条消息(共 6 条)
RenderQ
Hi, thanks for reply. I did try to remove the ENU and same behaviour. I have also set up some environment variables and custom startup script so not sure if they have anything to do with it. Anyway it seems like it is just a pop up and does not have any effect on customize UI functionality so I will just pass this as I don't want to mess my setup trying to solve this.
