CUSTOM MATERIAL.
CUSTOM MATERIAL.
CUSTOM MATERIAL.
Hello I'm trying to apply a custom picture to be used in my wall mounted painting as furniture. But when I render it, it only shows up as gray.
If you're wondering how I did it, I went to Material editor > Add material > Arch & Design > Add bitmap (under main material parameters, under it I went and pressed a small box under diffuse option besides roughness) > Apply to material to selection.
I'm not sure If i missed something, Does anyone have their own way of applying a picture on a object?
Alfred.DeFlaminis
Hello @Anonymous and welcome to the community,
I'd like to help with this.  Would it be possible to attach the scene file, even if it uses a different image if you need to protect that one?  I'm sure it's something simple but I need to get a look at it.  At first I'd say it's because of the default reflective value of the material, but that wouldn't make the reindeer/moose/whatever white.  Are you sure it's only in the diffuse slot?
Best Regards,
Alfred.DeFlaminis
Hello @Anonymous,
I just wanted to follow up here, any progress on this issue?
Best Regards,
