Cursor jumps on screen wrap at transform spinners...
darawork
Advisor Advisor
Message 1 of 80
darawork
Clicking on the transform type-in spinners (x,y,z) at the bottom of the screen, beside Isolate Selection and Lock Selection, and dragging down the screen with the mouse to change the values... the value will jump when the cursor wraps back up to the top of the screen. It should be a smooth transition when the cursor wraps around from bottom to top of the viewport, but it's not, and it's annoying.
It hasn't always happened, but only started a few weeks ago.
Has anyone experienced this happen? It happens to the two installations of 3DSMax 2016 here in the office.
Both running W10, and 3DSMax 2016 SP4.
Both have the same hardware specs as listed in my signature below.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Replies (79)
Message 41 of 80
Swordslayer
What version of 3ds Max, including the update:
2019.1
What version and build of windows:
10.0.16299.192
What is your monitor layout:
2 x 1920x1080, secondary monitor to the left & vertical
What is your monitor scaling set at:
100%
What monitor is 3ds Max experiencing issues in:
Primary
What kind of mouse are you using, and what is the polling rate:
SteelSeries Rival 500, 1000 Hz
What kind of video card is being used, along with driver version?:
GTX 1060 v388.13
Anything else you think is relevant?
I have the windows taskbar docked on the right and I can't use the transform spinners in the status panel at all, had to switch to using the F12 type-in instead because of this issue.
Message 42 of 80
uplink3d
Excellent response, thank you! well said/explained. I only wish more people at Autodesk were dedicated to fires rather than new features and software.
Everyone loses if we keep bouncing from fire to fire, so I hope that helps to explain why we haven't gotten to this yet.
Message 43 of 80
uplink3d
21.1.1.1320
win 10 pro 10.0.17134
2x Dell U2717D
2560x1440 No scaling
Both
What kind of mouse are you using, and what is the polling rate (see https://zowie.benq.com/en-eu/support/mouse-rate-checker.html😞
Logitech Performance MX
120 Hz
Nvidia Ge Force GTX 1080
it really felt like the problem started around the time the Windows April 2018 Update installed (I had the problem with Max 2018 as well)
Message 44 of 80
whitebirchstudios
Same here! It is just another frustration that we deal with.
Message 45 of 80
darawork
2016 SP4
Windows 10 - Build 17134.165
Dual side by side DELL UP2516D - 2560 x 1440 @59Hz 8-bit RGB
125%
Both
Logitech MX Master, 124Hz average
nVidia P5000 Driver Version 391.74
I think the problem started after the last 'big' update to windows a few months ago (Meltdown)?
Darawork
AutoDesk User
Message 46 of 80
J.Negrete
2019.1.1
10.0.16299
2 x 1920x1080
100%
All
Human Ergonomics EV mouse 500Hz
GTX 1080 Ti v399.07
I've experienced this in the 2018 version as well no matter what updates I had.
Max 2019.1.1
Win10Pro x64. i9-7980XE, 128Gb Ram.
nVidia GTX 1080 Ti
Message 47 of 80
mehrdad995gta
I have the same issue and its really annoying
Max version
2019 21.0.0.845
Windows 10
version 1803
OS Build 17134.523
Display setup
Single Display<AOC> (1366-768) -> Scale(100%)
-Graphics card
AMD Radeon R9 270X
-CPU
AMD fx8320
-RAM
12GB
Any fix to that would be highly appreciated 🙏
Message 48 of 80
Swordslayer
Message 49 of 80
darawork
I've recently started using 3DSMax 2019 (and a driver update for my card listed in specs below) and I don't think it's happening anymore. At least I don't think it's doing it anymore.
I'll update with a lot more details tomorrow when I'm back at the workstation.
Darawork
AutoDesk User
Message 50 of 80
darawork
Nope, I was wrong, the cursor still jumps.
3DSMax 2019.2 (21.0 - 21.2.0.2219)
Windows 10 Pro (Build 17134.523)
nVidia P5000 (Driver 391.74)
Darawork
AutoDesk User
Message 51 of 80
hagen.deloss
@mehrdad995gta @darawork and others,
Thanks for the additional information! I updated the internal tracking database with your OS and display settings, I really appreciate the help 😄
Hagen Deloss
Community Manager | Media & Entertainment
Installation & Licensing forums | Contact product support | Autodesk AREA
Message 52 of 80
uplink3d
14 months later... still no fix? does this not rate as a fire worth extinquishing? many quirks I can and have adapted to in 20 years as an autodesk user/customer, this isn't one of them. Am I alone as a spinner user? Do others have a better way?
3dsmax 21.3.0.3250
win 10 pro 17134.648
nvidia gtx 1070 24.21.14.1170
Message 53 of 80
mehrdad995gta
I've had this issue since the 2014version and apparently no one knows how to fix it, including the devs themselves 😕😕😕
Message 54 of 80
rodbrew2
Yep I still have the problem.  We have several workstations with Max on them and they all do it.  Several different types of mice and video cards.  Mostly Quadros.  I'm using a gaming mouse and have tried different sensitivities and resolutions to no avail.  The only thing that works is to go really really slow as you cross the bottom of the screen.
Super annoying.
Message 55 of 80
hagen.deloss
Hi @rodbrew2 @mehrdad995gta
Thanks for posting about this continuing issue! As @brentscannell mentioned, the development team is aware of the issue, and will hopefully be looking into it as soon as they can make a more direct effort to overhaul the way spinners operate within 3ds Max. Brent is one of the developers that would most likely be working directly on improving this feature, so I defer to him as the expert.
It does everyone a disservice if the development team is jumping around patch fixing every issue, without a holistic vision for the software and how all its elements interact.
In the meantime, @rodbrew2  if you would like to fill out the list previously provided above with further Software/hardware specifications, that would be extremely helpful!
I appreciate you all being so diligent with documenting this issue with the spinners, the forums community is such a helpful space, and that's thanks to everyone on this thread 😄
Hagen Deloss
Message 56 of 80
brentscannell
Thanks @hagen.deloss !
I will add that the development team is trying out a few things and that we may have a prototype of a solution ready for beta testing soon. I would encourage anyone interested in helping us validate a fix to please apply:
https://feedback.autodesk.com/welcome/default.html?key=3dsMaxBetaApplication
Message 57 of 80
chroma123
I can confirm the appearance of this problem with the windows 10 fall creators update. And it works when moving the cursor slooow when it's going from bottom to top of the monitor.
Message 58 of 80
this might be of some help to developers maybe https://kaetemi.blog/2019/04/02/fixing-the-mouse-wrapping-glitch-in-3ds-max-2010-on-windows-10/ please fix this very irritating bug
Message 59 of 80
brentscannell
Hi @Anonymous
Thanks for that link. I was about to post an update in this thread actually, as the developers have identified a potential fix for this issue and we are currently in the testing phase. We'd love it if some of you who have been experiencing this issue could help validate that we nailed it by accessing one of our test prototypes through our beta program. For those who aren't already part of our feedback community, there is a link to sign up in my signature.
Message 60 of 80
i can do that
i just applied for it
lets do this
