Cursor jumps on screen wrap at transform spinners...
darawork
Advisor Advisor
Message 1 of 80
darawork
Clicking on the transform type-in spinners (x,y,z) at the bottom of the screen, beside Isolate Selection and Lock Selection, and dragging down the screen with the mouse to change the values... the value will jump when the cursor wraps back up to the top of the screen. It should be a smooth transition when the cursor wraps around from bottom to top of the viewport, but it's not, and it's annoying.
It hasn't always happened, but only started a few weeks ago.
Has anyone experienced this happen? It happens to the two installations of 3DSMax 2016 here in the office.
Both running W10, and 3DSMax 2016 SP4.
Both have the same hardware specs as listed in my signature below.
Darawork
AutoDesk User
Windows 11, 3DS Max 2026, Revit 2026, AutoCad 2026, Dell Precision 7875 nVidia - Quadro RTX4000 ATA - AMD Ryzen Threadripper PRO 7965WX 24-Cores - 128GB RAM
Replies (79)
Message 61 of 80
madsd
@brentscannell
This has been fixed and verified working fine on win 10 and latest beta.
Works perfect on main monitor and slave monitor.
Good job 🙂
Message 62 of 80
why its not released then its a daily problem for all users !!
Message 63 of 80
madsd
If it's solid, it will go into the next point release, as with any bug fixing and updates like normally.
Apply for beta access if you want to test, as adviced by Brent above.
Message 64 of 80
you say it works perfect
that sounds like solid enough for what broken function we have right now
Message 65 of 80
brentscannell
I really can't comment on future release schedules or potential content, but as I mentioned the fix for this is currently in the testing phase with our beta community (just processed your submission, by the way). Once we are satisfied that the fix has been well implemented, we tag it as "ready" and we start the process of seeing where it could potentially fit in a public product release.
Message 66 of 80
ok i just beg you to make this urgent as its a very major fix
Message 67 of 80
madsd
Thats not how it works.
They cant just compile new versions for public for every bug fix, there are 1000s of fixes and improvements pr year.
And everything has to go through quality check, some thing that does work, proves to not work right after some time, or some does, and get flagged as Brent mentioned.
But get on the beta and have a go at it if you want 🙂
Message 68 of 80
your words makes scense if it was just a bug reported a month ago
but this problem been there for more than 2 years
i hope you don't mean by what you said that we should wait another year or so
we just need it as soon as possible
hopfully by 2020.2 update
Message 69 of 80
You wouldn`t belief what it sometimes take to fix a bug that the enduser receives as 'small and easy to fix'.
Trust me on this. I`ve been there...
Message 70 of 80
When is this going to happen ???
GUYS this is ridiculous i am in a Project for nearly two years now and was staying on 2018 because i got around that problem somehow. So i gave this a new try today with the actual 2020 Version.
like already described 1000 times here, throw out a Box try to move it with the bottom XYZ sliders and what a suprise the Unit jumps away when crossing the edge of the Screen. is this serious ??? ^^ what are you guys doing over there ???
Is this fixed within a service Pack now ??? Any Informations on that. this i frustrating ....
Message 71 of 80
It`s already fixed for a couple of months (2020.2)
Message 72 of 80
jshulters
I don't want to jinx myself, but I thought I'd update everyone that this screen wrap jump doesn't seem to be happening anymore for me with the latest version of 2020 (and on the exact same machine it was happening with 2018). Not sure if this was an intentional fix, luck, or a fluke... but I'll take it.
Message 73 of 80
It was intentional 😉
MAXX:UI
Wrap Cursor Near Spinner option no longer behaves strangely when used near screen edges. MAXX-51427
Message 74 of 80
yannick.deharo-extern
Observer
Observer
Hi !
I have this bug too, my version is 3DS Max 2021, and I have Windows 10.
Can somebody help me ton fix it, I need to use those spinners...
Thank you much !
Message 75 of 80
chroma123
Try slowing down your mouse pointer when it goes from bottom to top. That usually helps here.
Message 76 of 80
Observer
Observer
Thank you.
Thank you, I realized that my problem was different. I think I got the wrong topic. My cursor jumped to the bottom of the screen as soon as it flew over a spinner.
I corrected it by checking "Wrap Cursor Near Spinner" in the "preference settings".
Message 77 of 80
Waseem_Dabbas
Thank you for sharing this solution with us.
Message 78 of 80
dogzer
Observer
Observer
I've solved this issue by playing around with how displays are "arranged" in Windows. My current layout that works is below:
Message 79 of 80
darawork
I've not being experiencing this behavior recently with 2020 - 2022. Maybe because I only have one monitor (Sony 48" 3D telly, got one cheap on local adverts €230 quid). Working from home. But no more cursor wrap. Main work PC is on 2020 latest service pack. Home PC has 2022, no wrap. Home PC has GTX 760 461 nVidia Driver. Work PC has nVidia P5000. Latest drivers.
Darawork
AutoDesk User
Message 80 of 80
ciprian.onetiu
I resolve this issue by making my main display the monitor with 3ds max.
