3ds Max Forum
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max topics.
creating sections
3 REPLIES 3
173 Views, 3 Replies
creating sections
pretty simple i would assume, I just want to create a sectional cut down the centre of my building so I can then render it and have a section for presentation.
thanks
3 REPLIES 3
You could use a Slice modifier, but it will leave holes exposing the geom's hollow interior, Cap Holes can fix this in most, but not all cases. The other option is to use a Boolean to cut the geometry.
Steve_Curley
Slice Modifier. Add a Cap Holes above it or you'll have "open" meshes. You may have to mess with materials, because the slice+cap creates polys where there weren't any before and they will probably have the wrong materials on them.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
I will just be cutting through basic extrusions (lines which I have extruded).... can you give me a step by step walk through of this, im very new with the program. cheers
