Announcements
Create Shape from Selection
chrisbaker9552
chrisbaker9552
When I create a shape from an edge selection and I convert into an edible spline, it doesn't work as a split when I try to attach another spline to it or extrude it or create a surface from it?
Am I doing something wrong?
Chris
irishman_team_kilber
Try this see if this works
In the front view create a plane does not matter what size now take the segs lengh and width down 1 then convert down to a poly, go into edge mode, and select the four edges on your plane, under edit edges, choose the create edges from selection now put the dot in linear, and click on ok
on the main tool bar choose the select by name, you should have two objects in the list one is the plane and the other is the shape,  if you try and extude it then the spline will encompass the plane.
this should work on whatever your trying to model,
if this is not what you mean then please throw up an image or give more detail on wha you're modeling!
chrisbaker9552
Thanks!
It seems to work!
Not sure why it gave me such trouble before?
Chris Baker
UniversityWafer
Visit our online store https://order.universitywafer.com/
We can meet or beat almost any price!
Like Us On Facebook For Specials ! facebook.com/universitywafer
MMMM not sure why it did not work for you the first time.
Maybe you only had one edge selected who knows
